Components views wanted.
  1.2 Clio
Now i have a lovely new headunit. Thanks to Lee. (Cheers mate).
I want a new set of components now. I'm going ot keep existing wires in place but run more wires into the door cards and dash, so when i sell car it's easy to restore to standard. My HU is 50x4 Watts... that RMS! so i may not need to amp them up. Will be considered when i get the speakers though.
So considerations. Good sound quality, Volume - obviously, and Possibly easily amped.
With all that in mind i say these. What you lot think?
http://cgi.ebay.co.uk/ws/eBayISAPI....m=160235556322&ssPageName=STRK:MEWA:IT&ih=006
Recommend me some others if you like. Ideally no more than £60 but the cheaper the better ;)
Thanks guys
  BMW M135i
They're ok for cheaper ones, the kappas are much better if you can stretch to them (i've had both). It also worth amping them if you can too.
  1.2 Clio
Ok mate. Cheers for the RAPID reply.
http://cgi.ebay.co.uk/Infinity-Kapp..._trksidZp1638Q2em118Q2el1247#ebayphotohosting
Like those? Over budget means can't afford to amp... Which is better? Get the better ones, then save up again to amp them??? When i get an amp, should i use high inputs or the RCA's? I can select all sorts of stuff out the RCA outputs with my HU. Amp do i get an amp thats 85watt RMS. I know i could have less, but surely there's know point having one at 50Watt RMS. As my HU supplies that?
Thanks in advance
  BMW M135i
Pep
  M2,XJS,S1000RR
Just out of interest what headunit have you got that is 50W RMS?
  1.2 Clio
Ok thanks. It was just a friend of mine said highs were better, I disagreed!!! Cheers mate. I'll get those, then amp them when i next get paid. And thanks for the heads up on that other forum. :)
Thanks again :)
