almost anything u get will be better than stdQuote: Originally posted by GeeUK on 14 August 2004
Thanks for your reply.
If I do not know how powerful they are, how do I know if the ones Im going to replace them with are more powerful?
The back are the same size thou aint they?Quote: Originally posted by rancidrancid on 14 August 2004
wen i fitted my alpine speakers i had to cut the pod int the front to make em fit and theres about 1mm between them and the window when its down so nice and tight i duno bout the back cuz i aint done em yet
hope this helps
dan
Hi mate, Im from Huddersfield, not sure where Walsall is.Quote: Originally posted by Dan Page on 14 August 2004
gee where u from, i recomend components in the front and if u goto bass junkies walsall, the bloke in there (kelvin) will tell u the best speakers to have an will also fit ur components up front and coaxials in the rear for about £25, if you tell him that dan with the black clio sent you he will more than likely do em cheaper!
Anybody agree with this? Maybe I should just amp them up when I get my sub and amp?Quote: Originally posted by Irfan on 15 August 2004
i know its very temping to just change your speakers for better quality ones, but you wont notice much of an improvement, and sometimes they will sound worse. basically if you use the amp built into the head unit, cheap and chearful speakers are probably best, as they dont require much power to get them moving. if you amp the standard speakers they will sound much cleaner. if you then change the speakers, because they are already amped, you will notice MUCH more of an improvement.
if you dont know what i mean, check your headunit out. it might say it puts out 4x40watts max, but check out an alpine amp that puts out 4x100watts max, and look at the size difference. also, using component speakers require more power than coaxials as the crossover soaks up some of the power being given to the speaker.
another thing to note...a lot of the time some standard set ups seem to sound louder than a decent set up thats had a few hundred or even more spent on it due to them distorting more. if you go into a night club, it sounds fairly loud due to the ampunt of distortion being sent through to the speaker.
essay over (sorry lol)
