condensation in headlight unit
  Mk2 Clio 1.6
is it ok to have condensation in the headlight unit? i went to put my silvervisions in and noticed it on the drivers side!! dont know whether this will affect my HID's or anything??
  b/g 182, meg tourer
i have had this before. check that the rubber caps are on properly. and all bulb holders fitted correctly (no gaps for air)
mine cleared after a few days iirc
  Mk2 Clio 1.6
put the car in the garage earlier and went out to see if it had cleared up but its just the same!!
i fitted my HID's the other night so its probably to do with that, and i checked the rubber seals afterwards and they were on fine!!
what else could i do? peeving me off a wee bit!!
Chris
Ive read about covering the light in tin foil, Taking the rubber cap off at the back and heating it lightly with a hair dryer.
Apparently what some dealers do when they have this problem.
Alastair.
  986'S 172ph1+182FF
just drive around with the caps off for a bit the ya lights on will clear quickly
  Mercedes C320!
another quick tip is to put the lil silcone packets you get when you buy new trainers or a mircowave in your headlights. As these are designed to absorb moisture! Trust me it work...:) Oh and by the well my HID's were fine in my old headlights seems they steam up!!!
