constant knocking and vibrations
  Clio 182
hi a little advice needed,
i changed the passenger side shock on the 182 as the old one had lost all its fluid and badly worn the trye (which still needs changing)
however now there is a constant knocking when driving which increases with speed so do the vibrations
when i changed the shock thw cv joint track rods and ball joinys all looked in good condition ect
could the tryre be causing the knocking? or could.it be the shaft ect due to having a proper working shock??
regards
