sorry to be a pain i really am reanult charge 39.99 to do this and i can do it myself then i will how much fluid do you need to replace from new and s step by step guide including locations of where everything is to do the drin would be great how much does new coolant cost? any special make required
well it needs doing every 4 years dont it but my temp currentkly is at -17oc is that ok can i leave it for a couple more years?
Should be fine I'd chnage it at 4 ears regardless realy.i checked with one of those kits from halfords and it said medium protection -17 how long will it last for cheers could i get away with changing next year
I needed to change mine as most of it ecaped out of the pressure cap in the form of steam the other day becuase the temp switch failed to engage the fan when i was stuck in traffic
my engine bay smells and is filthy now:dead:
am i ok till next jnuary then mate do you think?
mine is over 5 years old now mate on a 51 plate so i think with those temperatures it suggets it has already been changed what you think?
i picked the car up last january and the rac report said the coolant was good for -21 had it checked this year and it is -17 so fingers crossed i am sure it will be ok for another year...does this mean to -17 the car will start no problem is that what its for? s**t who knows? i will defo get it done next year seems silly to have it done now hey?
Well you dont want that whatever the temperature is.
I sorted that out today. What a ball ache, dont have a hosepipe that would reach so had the run up nd down the stairs about 20+ times to get buckets of water to flush it all out.
