Coolant colour !!!!!!!!!!
Car  Renault Clio RSi Mk1
Hi...
I have a Mk1 RSi, I checked the coolant level today and its a orange/teracota colour....
What would make it this colour :S:S
Thanks in advance
Rust comes in a rusty colour lol.
You need to drain, flush and refill your system with a good quality antifreeze which should inhibit the rust in your block.
Is the water cloudy?
If it's cloudy, it's likely to be rust, if it's not it's likely to be the colour of the water/coolant.
Most blocks are cast iron, cast iron rusts if the coolant has been poorly maintained and clouds the water.
Remedy?, see above:)
Why is this site so damned slooow?
It is cloudy :(
I am going to be changing it this weekend.
Is there any flush stuff or just flush with water and fill with new coolant.?
Is there a particular coolant to use or any coolant will do ?
Also whats the easiest way to drain the coolant ?
Sorry for all the questions :o
Make sure you add it 60% coolant 40% water . Pure antifreeze can actually freeze .
I don't rate flush stuff personally, but some do.
It's usually a case of pulling off a bottom hose, draining it and rinsing it out with lots of water.
A garden hose is best, just stick it in wherever you can.
The problem is that the stat won't let you drain and rinse the block so you can either remove the stat(not recommended) or refill, run, drain and repeat until the water clears. Let it cool before you drain though.
Once it's cleared, drain and refill with and the correct winter % of coolant/antifreeze and it it shouldn't be a problem again.
I use halfrauds stuff and it's always been ok.
The secret is to change it a couple of times a year rather than when it become an issue.
Preventative maintenance is better than reactive maintenance.:)
The companies concerned say they get large numbers of complaints from customers who haven't read the instructions on the container and just poured it in straight, or did that in the mistaken belief that if 60% is good then 100% is better. You'd think they'd just sell it in the right concentration.
coolant comes in all different colours
renault use green coolant but i dont think it really matters mine is orange texaco coolant i wouldnt worry mate as long as your motor isnt over heating
your be ok!!
Well in halfords the cheap 2 year stuff is green and the expesnive 5 year stuff is pink.
