coolant pipework
  F4R'd ITB'd '92 cup racer
can someone post a pic showing where the coolant pipes run on a 172, ie which one runs to which inlet/outlet of the expansion tank
also from the water pump there is a pipe, that then has a T piece in it with another smaller pipe coming off it, where does this go? :clown:
pics would be spiffing, but a good description is also cool
thankin you :D
ah yeh forgot about that, just looking at it now
it shows a second pipe that joins the bottom rad hose from the expansion tank, im sure the pipework i got with it only has one T piece in it :S
anyone got a pic of the bottom rad hose, the rest i can work out :D
lol i've got bits of pipe sticking out all over the place at the mo
so the bottom rad hose that comes off the pump should have 2 pipes running into it, one from the heater matrix and one from the expansion tank
thats what the 172 diagram is telling me :)
