right some1 has just mentioned to me that i should know about the coolant on a clio......its not just normal water/anti freeze, u have to get some special stuff from reno??? that right??
if so how much are we talking??? and how much is the normal stuff?
Coolant is normal as far as I know in a 16-Valve. Look out for leaks from around the radiator - like the bleed screw. I had a little leak at the bleed screw and a cracked header tank, but a little Radweld and a new tank have worked wonders.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
