OK, so let me just run through this. Car tracks arrow straight now though can be very fidgety at motorway speed, always correcting the steering etc
Also, at full right hand down lick cornering over a rough surface, there is some real rough rattling coming through the steering
I pulled and battered at my suspension and steering and couldn't find a thing wrong :S
So here is what has been done:
Failed the MOT 2 weeks ago on track rod end, so that was replaced and full 4 wheel aligned
Top mounts/bearings + top washer mod - replaced 2 years ago with Lemforder branded stuff
Bottom ball joints -replaced 2 years ago with NWP items
Both rear shocks replaced 2 years ago with kyb gas items
Front springs - replaced 2 years ago after one broke, these were used cup ones I think
So I suspected the inner tie rods and gave them some real abuse tonight but for the life of me, I found no play at all
So, if I am right and assuming what has been replaced is still OK (maybe that is a wrong assumption?) The other possibilities are:
Wishbone bushes - I gave these some stick with a pry bar and saw nothing untoward, correct technique?
ARB bushes - again, pry bar abuse. No stupid play. Inner bushes slightly cracked and routers distorted under load. Best way to check?
Steering rack bushes - now I had a look at these based on recent posts here and they look OK, granted I didn't remove them to check. Could these be the full load knock I mentioned above. I'm on my todd here so its hard to load up the steering and check for play.
Would appreciate any input chaps
Car battles enough without borked suspension/steering
Jnj
