Hi, i have spent an hour or so searching the forums to try and find a similar problem but havent found any.
My 1.2 clio is dropping in revs when idle as if its going to stall, but strangely only when on a hill facing downwards ? dont know if this has any relevance or if its just a coincidence. Anyway i have taken it to the dealer and they have told me:
corrosion on injection computer connections, engine loom and computer required.
manifold pressure switch
- works
Seal Computer
Check Actis
Loom Engine
Capteur Pressi
Total 827.29 ex vat
I am sure because of 1 faulty connection or something they are charging for a full ecu replacement
but would anyone be able to explain a bit more what they are doing?
thanks in advance
- works
Seal Computer
Check Actis
Loom Engine
Capteur Pressi
Total 827.29 ex vat
thanks in advance
