front struts are coil over anyway, so never really understood the name but, setting them apart from most OE set-ups, they typically use much narrower 2.25" springs.
object is in improving ride/handling compromise, as any other spring/damper change. some will have adjustable platforms, allowing you to adjust ride height whilst unit is still in-situ
PS. are Clio rear coil overs actually 'coil over'?
that's the objective although i've no personal experince. could try a search or see what other replies you get. would personally be interested in learning people's opinions of how they affect both the ride and the handling, as there's a compromise between the two in any set up
