Done quite a bit of searching and there isn't a great deal out there.
My sunroof creeks as I drive, its very very annoying!
I used to own a mk1 Clio which had a leaky sunroof and I took that all apart and sealed it up. So this looks like a similar setup.
This sunroof doesn't leak. Initially I thought it was a cable or something loose but isn't a great deal up there. It seems to creek when the body is under stress.
I've had the glass out and undone all the 10mm bolts but I couldn't get the upper frame to lift at all. It appeared that only a brace on the inside was loose.
Running out of light and willpower I decided to pinch them all back up and put it all back together.
The creek is still there but reduced...
Anyone else had this problem?
HELP!
HELP!
