Has anyone else experienced this? Basically when I set my speed on the cruise control everything is fine. I can turn it off/return and increase the speed with the + sign. The only thing I can't do is reduce it. It just seems to cancel it completely? The video below shows what it does....
http://youtu.be/uUZWJ-79a04
Its temperamental and I have had it working once but 90% of the time this is what I get.
Also, so, is there an internal temp sensor for the clio? Easy to change? Basically when in auto mode, unless I set the temp to minimum or 16/17 degrees the fans will be set to minimum. I can manually increase it fine but it's as if the car thinks its warmer that it actually is, which I know isn't the case because I tried to set it to 26 when it was 9 degrees the other day and it just sat on one bar of fan speed.
cheers all.
cheers all.
