Cruise Control stopped working.
  Golf 7.5R & Clio 200
Used the cruise control today on my 182, but on the way home it wasnt working
The little green symbol on the dash wasnt coming up. I can use the speed limiter though.
What should I be checking first? And how would I do it?
  Ex 182 owner
it might be spring clip in the swtich. you can dismantle the switch and bend the pins back a bit so that it holds it better again when you rock it on.
  Liquid Yellow 182 FF
Mine is exactly the same after my gearbox change. it does work occasionally. I've changed the brake/clutch switches.
Jekyll
Ryan, do the switch trick mentioned above. Pop out the whole plate (it's just popped in so use a small flat headed screwdriver) the remove the cruise button and tweak the pins.
It'll most certainly be that.
