<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1 Transitional//EN" "[URL]http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd[/URL]">
<html xmlns="[URL]http://www.w3.org/1999/xhtml[/URL]">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Apects Building Company Ltd. - Extension One</title>
<link href="../Aspects.css" rel="stylesheet" type="text/css" />
<script type="text/JavaScript">
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
</script>
</head>
<body onload="MM_preloadImages('Images/Extensions/Extension01/ext01-02.jpg','Images/Extensions/Extension01/ext01-01.jpg','Images/Extensions/Extension01/ext01-03.jpg','Images/Extensions/Extension01/ext01-04.jpg','Images/Extensions/Extension01/ext01-05.jpg','Images/Extensions/Extension01/ext01-06.jpg')">
<div id="div-1">
<div id="div-1a"></div>
<div id="div-1b"></div>
<div id="div-1c"></div>
<div id="div-1d"></div>
<div id="div-1e" class="style4">
<ul>
<li class="menulinks">About Us</li>
<li class="menulinks"><a href="Ext01.html">Extensions</a></li>
<li class="menulinks"><a href="../New Builds/New Build01-01.html">New Builds</a></li>
<li class="menulinks">Services</li>
<li class="menulinks">Contact Us</li>
</ul>
</div>
<div id="div-1f" class="style3"><p>
Aspects Building<br />
Company Limited.<br />
Barry Smith,<br />
Fairview,<br />
Madeley Road,<br />
Belbroughton.<br />
DY9 9XL<br />
Office: 01562 711289<br />
Mobile: 07786 998089
</p>
</div>
<div id="div-2a"><p><span class="style1">Extension One</span><br /><span class="style2">Hartlebury</span></p></div>
<div id="div-2b"><img src="../Images/Extensions/Extension01/ext01-01.jpg" name="mainimage" width="400px" height="300px" id="mainimage" /></div>
<div id="div-2c">
<img src="../Images/Extensions/Extension01/ext01-01-small.gif" class="cursorforimages" width="50" height="50" onmouseover="MM_swapImage('mainimage','','../Images/Extensions/Extension01/ext01-01.jpg',1)" /><img src="../Images/Extensions/Extension01/ext01-02-small.gif" class="cursorforimages" width="50" height="50" onmouseover="MM_swapImage('mainimage','','../Images/Extensions/Extension01/ext01-02.jpg',1)" /><img src="../Images/Extensions/Extension01/ext01-03-small.gif" class="cursorforimages" width="50" height="50" onmouseover="MM_swapImage('mainimage','','../Images/Extensions/Extension01/ext01-03.jpg',1)" /><img src="../Images/Extensions/Extension01/ext01-04-small.gif" class="cursorforimages" width="50" height="50" onmouseover="MM_swapImage('mainimage','','../Images/Extensions/Extension01/ext01-04.jpg',1)" /><img src="../Images/Extensions/Extension01/ext01-05-small.gif" class="cursorforimages" width="50" height="50" onmouseover="MM_swapImage('mainimage','','../Images/Extensions/Extension01/ext01-05.jpg',1)" /><img src="../Images/Extensions/Extension01/ext01-06-small.gif" class="cursorforimages" width="50" height="50" onmouseover="MM_swapImage('mainimage','','../Images/Extensions/Extension01/ext01-06.jpg',1)" /></div>
<div id="div-2d">
<ul>
<li class="toplinks"><a href="Ext01.html">Extension One</a></li>
<li class="toplinks"><a href="Ext02.html">Extension Two</a></li>
<li class="toplinks"><a href="Ext03.html">Extension Three</a></li>
</ul>
</div>
<div id="div-2e">
<ul>
<li class="toplinks"><a href="Ext04.html">Extension Four</a></li>
<li class="toplinks"><a href="Ext05-01.html">Extension Five</a></li>
<li class="toplinks"><a href="#">Extension Six</a></li>
</ul>
</div>
<div id="div-2f"><p>This project started off as a four bedroom dwelling in Hartlebury. The main aim was to increase the two bedrooms immediately above the garage. The main problem with these existing rooms was that the sloping roof dramatically decreased the available living space.<br />
<br />
On the other side of the house we were asked to increase the size of the kitchen and incorporate a new utility room on the ground floor. This allowed us to expand the original bedroom on the first floor and integrate a walk in wardrobe. In the front elevation we were also able to include an ensuite for the main bedroom.<br />
<br />
The original main roof was extended above the garage. The side elevation wall next to the kitchen was completely removed whilst being supported. This allowed us to create the larger dwelling whilst keeping disruption to a minimum and allowing the day to day running of the house to continue.<br />
<br />
The works were started in April 2005 and completed in September 2005 which included refitting of the bathroom and kitchen.</p></div>
<div id="div-2g">
<ul>
<li class="thumblink">Previous</li>
<li class="thumblink">Next</li>
</ul>
</div>
<div id="div-3a"><p><span class="style3">www.aspectsbuilding.co.uk</span></p></div>
<div id="div-3b"></div>
<div id="div-3c"></div>
</div>
</body>
</html>
