Cup Pack...
Car  172//Crap Micra//Bus
Now I know there was a Performance and a Style one... but what exactly did each consist of?!
AFAIK Cup Pack was only an option on 182's
Styling Pack - Cup Spoiler and Splitter
Performance - Cup Suspension + Anthracite Wheels
172 was purely FF or Cup
182 can be FF, FF + Cup Packs or Cup
as above but the performance pack was not only anthracite wheels but uprated suspension aswell.
they introduced cup packs for the 182 which is what has eben detailed.
on the 197 its different wheels(theres a choice) and brembo brakes
Thought I would use this thread as there are about a thousand, but what is the big difference between the non cup suspension and the cup suspension.
By this I don't mean spacing but general difference in there performance ect... and is it noticible compared with the non cup suspension.
stiffer and lower springs from memory. The hubs are different which makes aftermarket changes difficult
I'd like to know which people think would handle better a 182 on sportlines or a 182 with cup suspension?
sorry what?
No such thing as a 172 ff
and a 182 ff is a cup packed 182
Noticiable difference?
Handling is noticably different and ride hight is noticable if next to each other.
obviously with sportlines the ride hight is substancially lower than standard so the dampers will be less effective as they're not designed to be that low. coilovers would be a good comparison and would work alot better at a lower ride hight than springs alone. You've got to remember the cup suspension is very good if you compare it to the trophy ones. If i remember rightly there wasn't much in it between the trophy and cup on a track test. Cup setup is a fraction of the money.
Could you retro fit trophy suspension to the cup packed 182?
Is there other differences to the trophy?
hubs are the same mate, so you could do. cost a fortune though at 1100quid +vat a corner. something like that anyway
Yes but there are trophy suspension for sale now and again, the main point is would it handle like a trophy?
I can't see how there would be any other changes to make the trophy so much better apart from the suspension.
the seats are more comfortable and huggy ;) and the one off paint, wheels and only 500 made. If you put the suspension on the cup it would be just the same though. Rear dampers are different also, not sure what springs are in the trophy dampers though.
you'd have to change the hubs mate, not sure how much that would be, and then cost of all dampers and spring all round. To be honest, having standard 182's gives you more scope to make the suspension more versitile. There are so many coilover options for the standard 182 without cup packs, so i'd go for them rather than cup suspension personally.
Hmmm good point. I definately don't want a cup. Just a cup packed 182.
Maybe it is best in the long run if I get a un cup packed 182 for when I decide to upgrade the suspension?
If you're looking at changing the suspension you'll be better getting a standard 182 without cup packs. Cheaper to upgrade suspension and much more coilover options. Think there is only 2 options for the 182 with cup packs and they're both 1K plus.
Thanks for the advice I'll see how the sportlines feel and possibly upgrade to coilovers in the future
Is it possible to have 182 cup suspension and whack some sportlines on?
Yeah I'm struugling masively finding suspension, think I'll end up renewing the standard dampers then get some Eibachs
