Cup pulls left
Car  Cup 172
My Cup always seems to pull to the left...
Normal? Seems particluarly pronounced on roads like the A1 where you are doing pretty high speeds, but could just be the camber?
Had the tracking done and its made no difference!
Depends where you get done. If you get on a proper laser rig set up they can advise of camber etc and I found my valver runs more on rear at one side than the other which cannot be adjusted at the rear. So from factory like that or from use.
Can get car adjusted to compensate however. Expensive but sorts handling out and ideal when getting car lowered or coilovers fitted.
