Cutting exhaust cut out on 172 bumper
  Megane 225 F1
Should be fitting my 172 bumper this weekend. Whats the easiest way to cut the hole out for my exhaust?
  Clio 1.2 16v
No but im sure i can. What about lining it all up or is it guess work?
im guessing cant, u if u havnt already, put ur exhaust on, fit the bumper and mark where the exhaust hits, measuring is another good way if uve got a good head on ya or yeah guesswork only ways i can think. as for cutting it out im not to sure but for be id get the general shape then wack a circular scotch bright abra disk in a drill and slowly smooth it to prefered shape. dno if that helps
  Evo 8 MR
Take it to a bodyshop ftw, cost me £50 to fit my cat back, cut a recess in the bumper including fitting and painting the surround.
Unless you feel competent to do it I wouldn't even attempt it.
  Megane 225 F1
Will the plastic split? Or should i use masking tape like they taught me at school (one of the few things i remeber)
Remember always start far too small, then work away at it checking with the exhaust until you have the correct sized hole. Much easier to sort it being to small than too big.
