CV boot clip broke
  R35 GTR
Grease everywhere!!
I need to fix it tomorrow, anyone know where to get some mahoosive jubilee clips or similar? Halfords dont have any. I have a cable tie on at the moment, but dont think I can pull it tight enough.
Renault supply then with the new gaiter and grease as a kit.
Only cheap £20 or so I think.
No point trying to fix them IMo though just get a new shaft much less haslte.
  Lionel Richie
but you need the special tool to clamp the renault clip
we've just done christurbos mk2 172, very common
  tiTTy & SV650
renaults is probably some fancy ass cobra clip.
any decent hardware shop dave or a plumbers merchant, B&Q, etc
good luck with the interview, if you had more time I could sort you out with a jubilee clip no probs but aint really feasible.
Try a motorcycle dealer they often have big ass jubilee clips / cobra clips round the exhausts.
Good point.
Other option is to bodge it use one or two jubilee clips to go round.
Dave I meant new driveshaft. If you have big balls on the drive shaft stretching the rubber to fit is a pain.
  172 cup'd extreme
you wont fit another boot over unless you get the joint off and this is a b*****d.
I used a large zip tie last time was ok for 6 months then changed to a metal clip any car shops sell them.
  Burgandy 174 sport t
I used a jubilee clip before but found that a tie wrap is better as it sits in a groove where as the clip is wide and sits accross it if that makes sense.
Just pack it full of grease and tie wrap it up it will last a while without the need for a shaft.
  CTR--VX220D
And what a good job you did of it :)
Mine went due to the battery side mount breaking and the loose engine putting pressure on the CV joint.
Here is a pic fixed:-
BTW my 172 is back from Yozza and I cant stop taking the smile off my face!
