cv joints
Car  RenaultSport clio 172 cup
took my n/side front alloy off 2 give it a proper clean n discoverd it was caked in grease. looked the other side n it was the same, looked at the rubber gators n they seem fine. is it 2 cv joints n if so any idea of the cost involved. cheers steve.
the grease must have come from somewhere so probably a small hole/cut in the gaitors. gaitors are around £30 each then whatever labour the garage charge you probably at least 2 hours
thanks for the advice guys. its booked in for tuesday, will have 2 use it for work till then but will take it easy and keep an eye on it. cheers steve
