cv rubber leaking behind wheel...
  Audi S3 225
Hi, just wondering how much of a problem this is and how expensive is it to fix, ive had a a look it is behind the front drivers side wheel, there is a split in the rubber and there is oil and crap everywhere im worried it will go on my brakes.
Do i just need a new rubber and are they easy to fit?
Allan
  tiTTy & SV650
should be more worried bout the cv joint / drive shaft running dry get it replaced asap. wheel off, disc off, hub off (not 100% about what you need to remove on the clio) takes time garage would charge bout £80 - £100 to do it cause of the time involved. You can get universal gators which are split and u glue on, theyll fail every few months so not worth it. I used to always get the biggest universal gator i could and shove it in boiling water to stretch it over the hub etc, then secure with cable ties, always worked and much much cheaper.
  Audi S3 225
so cheaper to do myself, all i need is the rubber they cant be that expensive. How mcuhd riving can i do, before i damage my car?
About £30 for the new rubber from Renault, as a temporary fix, pack it wiht CV greae, and patcgh it up wiht a bike puncture repair kitm, will last for ages
