Been out in the car this morning and the light has gone out which is great.
Nop... the problem is there. It will blink again! You have to erase that.
After all i think that cruise control is not working properly....can-bus systems!
That sounds like a likely cause, I has the seals on the cams when I fitted the rocker cover (I did have the correct one on correct cam) and the inlet did get caught at an angle as I started tightening it until I realised! F00k!
Is it rocker cover off again or as the inlet seal has a larger inner diameter than cam do you think i'll be able to get it out?
Take a screw and kill the f*** seals... take them off and then do what sideways danny wrote.do you think i'll be able to get it out?
Hi dan did you manage to get to the bottom of this fault as I have similar issues many thanks benits weird, i've driven it a bit this morning and sometimes it does it, sometimes it doesn't, when it doesn't it drives and pulls spot on! does that sound like timing or something else?
where would I check for air leak?
