cylinder one misfire po301
Car  clio sport 172
hi wondering if anyone can help me with this
car has a slight backfire and engine seems to be rocking no loss of power tho changed, spark plugs , changed ht leads, changed lambda sensors ,changed coil pack, no real loss of power, gavin
I'd try and pick up a set of 2nd hand injectors, mine was misfiring and i did the same as you, leads, coil pack etc and then i got a set of injectors off here for £25. Swapped the whole fuel rail over and misfire is gone :)
If you have a multi-meter to hand switch it to read resistence and put the probes across the two injector terminals - Let us know what reading you get.
