Daily bucket seat options
Adey.
Hopefully this is in the right section?
So bit of a story, I've had a fair chuck of surgery to my core and its still pretty ruined, as such doing a track day writes me off for days. The stock seat and belts in my Clio 4 aren't overly supportive and i end up using what core strength I have to keep my upright and in the right place. So I'm looking for something else just for the drivers side.
My issue is the car is a daily driver and only used for occasional track days, but i defo want the support when required. Id like something i can commute in and still be relatively easy to get in and out of. I'm also a fatty so needs to be for the bigger boned person.
What are my options, shell out for some ropey CS Recaros? Harnesses i don't mind removing as and when as long as i can us the oem belt too. I did have oem clip in harnesses from schroth back in the day that were used on the stock leon cupra r seats, is there anything like that available for the Clio?
Thanks in advance
First thing i'd say is try sitting a few different people's cars with bucket seats, some are mega comfy, some are hardcore race seats.
You going full fixed bucket or recliner?
I know recliners aren't ideal with harnesses, but for a road car that does the occasional track day it might be worth considering, a lad I knew when I lived in Nottingham had a 182 with Sparco recliners, they were comfy as f*ck and he was using OEM seatbelts.
Tillet b6 XL 43 Screamer.
It’s what I have in mine. Super comfy , super supportive and easy ( in a Clio! ) to get in and out.
Always welcome to test in mine if needed.
Granted haven’t dailyed it with them in, but my Corbeau Clubsports aren’t the worst thing in the world. They’re XL’s so nice and roomy. If you got something cheaper like that, you could always replace the foam in them with some memory foam or something?
I had Sparco EVO3 in the flamer way back when (in XL size) and they were comfortable enough for me to do Le Mans and back. Unsure if they still make them?
Cheers all,
There's some flash options in there! pole positions and the tillets are around 1k looking about. Looks like i need to spend 500 on subframes for the CS's after buying them too to make them fit the CS4
Sparcos and Corbeaus are more my bag/price range :D
I've been looking for seats recently and I've seen all sorts for sale.
If you just want some comfy seats with the option of a harness, there's plenty of factory fitted Recaros for sale on FB marketplace, they're not fixed buckets and you'll need to buy mounts, but if you're budget conscious it could be an option.
It's worth typing Recaro in FB marketplace, see what's out there.
Just buy a cheap seat and mount, put it in night before is your best way I'd say, you'd need to use a harness also on track to keep you snug 👍 i have some cheap corbeau thats fine, not very comfy for daily driving though
I just bought this for £120, it's not fancy but it fits my middle-aged arse, even has sliders fitted.
A mate gave me an omp base, so I just need a pack of big bolts and I'm good to go, it can be done on the cheap.
I have a Corbeau Pro-series X in my Clio and it's SUPER comfy, however the sides are very tall so it's a bit of a chore to get in and out of. I'd probably spend my money on something like this - https://www.corbeau-seats.com/product-page/pro-sport
If going fixed back I'd avoid anything with a steel/tube frame as they get uncomfy fairly quick. You want a GRP/carbon/kevlar moulded seat, way nicer for longer stints. Mine is only a track car but it was road legal last year, drove down to Engine Dynamics and the 5 hour round trip was only a chore on my ears.
I’m going through the same thing. Although I don’t daily mine I don’t want it to be a pain getting in or out. Have looked at the Corbeau pro sports. The people who I’ve seen have them say they not the most comfortable for long distance as the padding is thin. Spoke to Corbeau and they said the can double up the padding thickness to hopefully cure that. Have also looked at a cobra nogaro, bucket seat but with low sides to make getting in/out easier. Corbeau have also today released a new seat, the Q1. Looks a lot like the nogaro but made by Corbeau. Going to try and get down to Corbeau when I’m back from spa and try a few seats before I buy one. Only reason I’m looking at Corbeau is they’re only a hour from me.
Bucket seats are never as comfortable as normal seats, I have Sabelt GT3's in mine, great for 20 min stints on track, not so great on the 150 mile drive back from Cadwell park. I wouldn't have them on a daily. You may also have problems with wear getting in and out with daily use.
I would want some Recaro CS rather than buckets for a daily.
P.S. I have Recaros in my TT and they are very comfortable!
I don't know if I've lucked out with my seat selection or all you are just mard arses. I've got a Corbeau Clubsport XL and its extremely comfortable. It's on a standard sidemount subframe. I've got a Jon Foz subframe to fit but not got round to it. The Clio isn't my daily, BUT I have daily'd it in the past when my dailies were broken.
I went through a short period of thinking it was hurting my upper back, but it turns out I needed a small 1/2" steering wheel spacer, as I was leaning forwards and jutting my chin out with realising it. The second I fitted that, any discomfort went away. Its also been perfectly comfortable on 2+ hour drives, as well as extended everyday use. Obviously everyone is different, but they're worth a try and will also sell on.
It's also only 4 nuts to remove under the car to take it out, so there is the old "put it in the night before" method like someone else suggested.
Edit: Looks like Corbeau have done a second redesign to the clubsport. At first it was a Recaro Pole Position clone, then they changed it to have the awful square-ish large harness holes, which made it look like a gaming chair. The new Prosport looks like the old Clubsport but with copywright dodging triangular harness holes.
I went to GSM years ago to try out a bunch of seats, and for me the Mirco range was quite comfortable and well fitting. I'm 6 foot 2, and around 100kg, waist roughly 36 inches.
At that time I ended up buying a pair of Corbeau Clubsports for £350, as they were so cheap, I think the Mirco's were more than double the price. But having owned both now, the Mirco are much better quality and better fitting for me.
I now have a Micro GT in my Z4, which I picked up second hand off eBay a few years ago, and have installed in a few cars now. I wouldn't say they're amazingly comfortable, but for me they are more comfortable than the original seats, as i don't fit in them, and i'm quite happy driving 2-3 hours in these.
If you can, i'd 100% recommend going somewhere with a large showroom, and sitting in a bunch of seats in your price range.
