Dash Error
Car  Ford Fiesta ZS 2013
When I start the ignition sometimes I get a flashing error on my milometer saying "oil -------------" I checked the oil and its fine? It has the service light up to? Anyone else had this issue before? It flashes with those lines for a minute or 2 and then it shows the millage as normal but the SERV light remains on?
Guess he did that bit already.
I guess there'll be an level swich somewhere near the bottom of the block. You could try checking that? I would presume a closed contact when the level is ok and a open contact when the level is low.
Are you parking with you front end higher than the rear (on a hill) as this can make this happen as the oil is there, but the sensor cant see it so brings warning up.
I'm pretty sure that just means it needs a service or it hasn't been reset since it last had a service done.
I think you turn the ignition on while pressing and holding the mileage reset button but it's been a long time since I've been in a Clio.
The level senders do go faulty (My Laguna Turbo did this a couple of times and then stopped doing it till the day I sold it) and when they do they tell the dash there's no oil hence the warning.
If you are 100% sure the electronic oil level check reading is incorrect and have confirmed the oil level by the dip stick then It could be a wiring fault but it could be the oil level sensor itself.
Thanks for the reply's! the car was on a flat surface all night started it up at work that night and the error came up. Left the car for a few hours and started as usual and no error. Suppose its just an electronic glitch that just happens now and then? Hmm thanks all!
