Dash Fog light flickers when I press brake pedal
  Fabia vrs tdi
Dash fog light flickers when braking on my 182. I had a look under car at Fogs and looks like on the left had side there is a black ribbed plastic tube loose with no visible wires where as on the other side its connected up to something. Not checked if both Fogs are workin at front or not sorry should have checked first
If you have a look at the drivers side rear light cluser, give the connectors a quick clean up with sandpaper, this is whats causing your problems.
WD40 the inside terminals leave to soak for 5 mins, Get rid of excess oil then fit back. Worked for me over the cleaning prongs and earth leads.
