Try taking rear light units off disconnect the wiring and spray connections with contact cleaner. Might be dirt or condensation causing the problems. My fog light on the dash lit up dimly when braking and contact cleaner fixed that.
Swapped the lights over and its fixed the problem on the dash but now my fog light wont work?
Tried swapping the bulbs over with no luck. Its not meant to be a bulb with the 2 elements in it is it? It was working before and I have swapped bulbs now as well.
Are the passenger and drivers side bulb unit bit the exact same?
