Dash Problem?
Can any one help? every time i start my 172 ph2 sport, the computer resets its self and all the dash readings go back to "0" every time? any ideas? thanks Andy
Does the same happen with the radio?? Mines staying on even though I've taken the key out of the ignition??
Not that I am aware off mate.......have you taken the radio out recently e.g. disconnected the wires at the back? If so double check you haven't put swapped the permanent live and ignition live around when re-fitting.
I haven't taken it out but I don't know if the previous owner had an aftermarket headunit, I've only had the car a few days.
Do you think if I swap the permanent live and ignition live over in the ISO it'll fix the issue? I did it on my old car for my aftermarket headunit.
Do you know what colours the wires are?
I take it the release keys for the standard headunit are the normal U bend pieces of metal?
Sorry for the hijack.
Battery is your problem with resetting of your trip computer. battery will test ok tho if you test it mine did. It will also start ok but it does cause the resetting.
So was mine mate, but it doesn't hold enough charge when you start it to keep the dash readings.
A battery change will sort it.
Permenant live and ignition live are red and yellow. swap em round so their both half red half yellow as u already know. Jobe Done
