dci cam belt
  clio sport 15dci
at what mileage and roughly what cost for changing the belts on a 1.5dci 06 reg .someone recommmend in west yorks or fairly local with the correct renault tools would be good. thanks
  Astra GSI, 172, Golf
think its 62k or 5 years .
i did mine myself bit tricky to time up as you dont time the bottom end from the pulley you do it with a pin at the flywheel , a 6mm allen key does the same job tho ;) . then line the marks up on the belt with the cam and fuel pump pulley .
think its a £200 ish job tho dependant on were you go .
  Clio 182
Hiya mate if u fancy a drive 2 norfolk i'll do the job 4 200 quid includin parts. Cambelt change is due at 72k or 5 yrs. Has yours got a/c? U need lockin pins plus if it has got a/c u need a special tool 4 tensioning the aux belt.
