Dci Gearbox
Car  big boost cup
Just wanted to know is it possible to fit a dci box to my cup, without lots of hassle.
I know there are a few people running them on there turbo clios
The Ph2-> clio ones will probably be no good for you as they all came with abs speedos. It'll have to be out of something else I think, research required anyway.
I'm pretty certain I've read it... On one of the 'charged Clio's.
i bilieve thats scoffs mk1 with f4r engine and vag gearbox, not a striaght fit, custom bellhousing afaik
tom if the speedo is run off the abs on the clios then theres no need for a drive off the gearbox that the cup uses (as the cup doesent have abs so it needs a way of transmitting speed to the clocks) so if it hasnt got a hole for the speedo drive on the box then you wont have anywhere to plug your speedo
Jaffman i see now looks like this could prove difficult then dont suppose there is any other box that will fit, without lots of fabrication?
Just be aware all 3 dCi boxes are different...
65 - JB3 969
80 - JC5 128
100 - JR5 120
Typically Renault tbh
65 - JB3 969
80 - JC5 128
100 - JR5 120
what do the turbo boys generally use out of those 3 then? im building an f7 turbo so i would be looking into getting a dci box
You can reprogramme it to register off the abs with clip mate ;)
might be worth a call to agency transmissions in worcester, see what they can do with your existing box to make it stronger
