De-Cat - 1.2 16v - Performance or standard ?
BREMBO
  V6 Mk1, Golf GTI Mk5
Needing a new de-cat for my car.
Wondering if its worth getting a performance one or just sticking to a normal one ?
Ben
eh? theres no such thing as a standard de-cat! Presume you mean you need a new catalytic converter and should you get a decat or sport cat or standard cat. As you have a 1.2 jsut get a standard one as it will make f**k all difference getting a sport cat or decat and if you get a decat you will still need a standard cat for MOT
  Cupra 300 ST 4drive
prob a 250 cell cat, Why do you want a decat on your car mate, its a lot of money for fu-k all .
BREMBO
Think im getting mixed up. Its a standard part on the car but needing replaced but wondering if I should get a better one ?
  mk2 ph1
You have a CAT as standard. K-tec do a sports CAT, which is really half way between a CAT and having a De-CAT (no CAT at all, just a pipe) which may pass the MOT, seems to differ from car to car.
If you do need to replace it go to a scrapy or if you do want a de-cat any decent exhaust place should be able to sort you out. My local place is Pro-speed so £40 and i had a nice de-cat
  Breaking A 172 Replica
Get the standard cat again if I were you mate. The 1.2 16v engine as fitted to your car has some weird flexy joints and therefore exhaust places can't readily make up a decat for you as JamoJamoJamo suggests.
BREMBO
Im I better paying £200 plus for this or getting one from a scappy then getting someone to fit it ?
Staying standard by the way
BREMBO
Will end up cheaper than 200 odd then.
Good news - Thanks people
rctempire
Brembo, you could do it yourself on your drive way. Just jack the car up and support the front with axel stands.
Socket and a spanner on the bolts, take the cat off, then replace it, its a swap out and straight swap job.
BREMBO
Another question...
Whats the diffrence between ceramic and steel ?
Which one should I get ?
ceramic is cheaper but wont last as long (will still last a long time) stainless is more expensive but will last longer, not worth it imo unless you intend to keep it untill the car dies
