De-cat only
Chris205
  Many Things
Which company supplies a de-cat that will fit to the standard system? I'm after preferebly a 2.5" bore if that's possible.
  Lionel Richie
not possible on the stock fitment due to the trumpet flange, they'll all have to reduce down not that it matters that much
Austin-182
  182 & Dci 100
Mate why dont you just get a full system instead of the rs map? The map's £100 cheaper with their deal theyv got on but itl will end up costing more in the long run
  Astra SRI/ Hornet
junction26 has scorpion ones for 57 quid on ebay now. i had 1 on my 182 standard exhaust and swapped with dave ramseys mate for cat when i sold.
  Ph 1 172
Cheapest Decat I could find was from North west performance on here at the end of the day it's a bit of bent pipe, although that said does seem a nice piece of bent pipe from NWP.
Danith
  VRS 230 & Ep3
ooooooooo trumpet flanges!!!! I'm so hot right now.
Pipewerx near me might be able to box you off kidda. They quoted me about £100 fitted I think. Dunno if I can be arsed with MOT ballache tho.
  STEALTH RAIDER
Ill second domjolly's recommendation although i havent had a decat from them. I had my silencer removed from my 200 a few weeks bk along with its first service and they were superb. Also NWP are very competetive but dont need any haggling as their prices are cheap than most if not all.
Chris205
  Many Things
I'm getting a system before I get it mapped mate, that's why I want a de-cat ;)
Austin-182
  182 & Dci 100
Why did you ask for a decat that goes to standard system then? Are you booked at AAS
Chris205
  Many Things
Because the exhaust I'm getting is to fit a standard cat, so whatever outlet is on the standard cat I need to get a de-cat with the same diameter etc ;)
