Decat fitted engine light flashing
  Clio 182
Hi iv recently had a decat fitted car was running fine, yesterday driving the car almost went into limp mode and running terrible making terrible sounds from the exhaust. The emissions light is now constantly flashing. I have connected my diagnosis machine up and it’s not showing any fault codes. Any ideas? Any help would be appreciated cheers.
  182 clio
The should be a code stored if eml came on or is flashing.
Most time flashing eml points to misfire detection
MRBILLYUK
  FF Jeden Osiem Dwa
Usually when you fit a decat and the light comes on it's a constant light not flashing and doesn't affect performance.
Sounds to me like the lights flashing for a different reason.
I've certainly never heard of it putting your car into limp mode.
Daz...
  Inferno 182 Cup
Flashing EML and rough running will usually be an injector. Take the fuel rail guard off and while it’s running unplug each injector and see which one makes a difference, the dead one should be pretty obvious to find.
Louis
I Love Ed Sheeran
Are you sure you didnt damage the precat sensor? Most likely injectors anyway and decat is a coincidence
  Clio 182
Changed the leads and coil packed sorted it, strange to not see a fault code tho. Glad it’s sorted thanks for your reply’s
