Decat help, arrggg
DrR
Car  VW Golf GTD
How the hell do i get the sensor out the cat? Been pounding away at it for ages now! ggrrrr
Had the blow tourch on it everything, it's not a reverse thread or anything is it?
butter lol
sorry - i'm of no help but had to post... just had to.
Mine was like that, my removal method, spray wd40 on the inside & out & leave for 10 mins.. repeat this again then carefully place it in a vice & take the correct spanner too it, job done! i reaaaally strugled with out the vice, got the first one done but the last one :mad: ... well worht the strugle though :approve:
Done, Massive pole + adjustable + vice FTW That has to be the hardest bolt i've ever undun,
Do i need to put exhaust gum on it as there appears to be none on the orginal cat?
its very hard to undo. glad to see you managed it now.
when i undone mine i took it for a drive to get it hot first, was still tight but it was easier
Well it's on and sounds no different on tick over :(will go for a drive in a moe see what she's like.
I'm running standard exhuast, update to follow woo, excited lol
Ran mine on the 182 with standard system, does sound different, quite liked it in the end!!!!
I had just a Decat on a Std system for a few Months on my 182 and I loved the sound of it, you will notice a difference in Sound on a run
Sounded hardly any different, sounds like it's blowing although pretty sure it aint.
you are not supposed to use any paste/gum infront of the cat but anything after is fine
but because you now have no cat get plenty wacked on, decat is really the way forward, and lpg makes it legal too :D
