mikekean
996 C4S, 135i, E30x2
Hi Guys,
Went to fire up my cup racer today after having replacing the cams and the timing belt. And now there oil is pissing out of the dephaser pulley seal, I fitted a brand new seal when i changed the cams and i was careful when fitting the seal and dephaser pulley so as to not damage the new seal. But it seems something is not right, pretty pissed of as its covered the new timing belt and everything oil.
Is it possible to fit the seal the wrong way round?
Also i dont appear to have a spark, i tested againt the block with a spare lead and plug i had and i get nothing. So i checked the datalogger to see if i get an rpm signal when cranking and i get between 150-300 rpm so i dont thing its the TDC sensor. The coil on the car worked fine when i took it off the car 6 months ago and has not been dropped or anything since being in storage. Any ideas what it could be?
Mike
Mike
