Dephaser?
_WILL_
  172 Cup
Engine is ticking quite loudly. I did the belts, dephaser and water pump about 6k / a few months ago. I have been Reading threads and listening to other people's videos but I am just not sure.
is there a definitive way to tell if its defaser? If its not the dephaser what else should I be looking at?
engine is on 100k and I changed the oil and plugs at the weekend.
I have a video but I don't think it sounds as bad on the video. I am hoping I am being paranoid tbh.
http://youtu.be/SH9hhU0vCyQ
_WILL_
  172 Cup
It had Bosch ones in, when I serviced it I replaced with Bosch. That was a mistake!! So I swapped it NGK yesterday. None of these plugs has effected the ticking noise tho. They did make it run a little s**t tho!!
Sent from my iPhone using Tapatalk 2
_WILL_
  172 Cup
I have listened to the video again and it is the ticking noise that I can hear on the car, it follow the revs until it is drowned out by other engine / exhaust sound.
  Clio 172 phase 1
sounds a bit dephasar ish ... recently i had the worlds worst sound coming from mine sounded like the internals of the engine were escaping.... turned out to be a bolt had fallen out of the alternator bracket at the bottom and the alternator was just banging about. could be worth a look
  Fiesta ST2 MP215
Sounds like the Manifold issue I had, bolt springs snapped off and the bolts were hanging out, issue being they are hard to see unless you have a ramp but was the last thing I had looked at. easy as to change though.
_WILL_
  172 Cup
Sorry, which bolts. Mani to block or mani to exhaust.
_WILL_
  172 Cup
Cool. I will check them. Tbh honest I have had the engine out fairly recently and mani off again for a starter motor issue so I will give them a check as could easily have missed something.
_WILL_
  172 Cup
Check ur spark plugs r tight man when I got mine it was making a wild tick turned out some ball bag had no tighten up the plugs right
I thought that as well so I have checked the torque on all for. Have set them to 25Nm.
Interestingly while looking I notices that the main pulley for the aux belt, the crank pulley has a wobble. Which is a little convening. I will post a video of it.
_WILL_
  172 Cup
Ah ok, appologies!
Fred, can I toque up, or at least check the torque of that pulley without removing too much? I can't remember for the life of me if I removed it to do cam belt?
Also do you recognise the noise in the first video, could it just be noisy injectors?
_WILL_
  172 Cup
So after some messing around today I have found the following.
The pulley has a wobble, so I will change that when I can but not urgent.
The crank pulley bolt is defiantly torqued up correctly now.
And the timing it out. Not by much but defiantly out. I think I got it slightly wrong when I did it originally.
Not really sure of the best plan moving forward. Seems like a right hassle to put it right!!! Not sure what the best way to do it will be. Belts are only 7k and a few months old!!
