Diagnose my fault
imprezaworks
Car  Mk5 Golf GTI :)
Basically when the car is cold it splutters like its cammed, unsure if it is or not. Under load in the morning it's hesitant like something is holding it back. Give it five, ten mins and it behaves itself but I can still feel the car vibrate. The car is stripped so it is prob more obvious. I've replaced the leads and plugs and its no better. It's not a real problem but something I want to sort. Engine sounds good and it pulls etc like no ones business. Anyway we plugged it in to a snap on diagnostic and it pointed to the rear O2 sensor being faulty. Now my understanding is that the second O2 sensor doesn't do much, it is still plugged in though. From my brief description do we think its O2 related? Car is decatted too. Cheers chaps. Oh and would it be worth swapping the sensors around?
Did you swap the sensors? Loads of people have run decats including myself with no issues before.
I'm having similar problems ATM. I haven't tried to fix it yet. Mines is 100% injectors, though.
Ok gaz thanks. Will swap the sensors over tomo and go from there, my luck would be that both are knakered lol
I had the same, had the injectors refurbed and it was like a new car. It was showing a lamba sensor fault too, but seemed to pull fine regardless.
Lambda doesn't get used when the car is stone cold.
The sensor working is probably whats helping it to run a bit better when warmed up.
You mean you don't know either lol. One thing I do know is that the fuel rail guard isn't there. Ignore that stupid ass comment
Hassle sending them away mate. Is euro car parts worth a call? Can get half decent discount with them
Ok cheers chris. From reading about its worth swapping the O2 sensors around, on my list to do tomo. Needs to be right for a trackday a week Tuesday
Cheers. Swap O2 sensors, remove fuel rail and check each injector. Well that's the plan lol
You should buy something Japanese and reliable pal.
Ever thought of getting shut for an EP3...
My car is super hesitant till its warm tbh too. My cammed saxo was exactly the same! I replaced my injectors when i got the car and its still hesitant when cold i think its just one of them things...
Will give those couple of things ago and see what happens. Been using bp fuel since I've had it, well on stuck thirty quid in on Sunday, will fill up with shell tomo just to check that
Swapped the sensors over, seems better, see what it's like in the morning. Big thanks to everyone who has helped. £12 membership warranted in one day :)
