Dipped Beam Light
Car  RenaultClioWorldSeri
I tried fitting H7 35w xeon hid bulbs to my 09 mk3 clio, i took out both orginal bulbs and replaced them with the hid bulbs i turned them on there was no sign of light, i put the orginal bulbs back in to see if something was wrong then they did not work either, i check all the bulbs they were not damaged or blow so i checked all fuses and they were fine too
does anyone have an answer for what is wrong here...?
ummm do you have the ballasts, starters etc? if you have just the bulbs its not going to work...
you need the whole kit if your doing a HID conversion.
Plus if your thinking about putting them in a reflector headlight, please don't, for every other drivers sake! will blind everyone! Make sure you have projector headlights
Yea iv tho whole kit for the conversion thats whats confusing me everything is there and ok just not working anymore /:
