Ditiching climate control panel
Car  172
Ive done away with my aircon. Just wondering if i can remove the climate control panel and swap to a manual version out a cup or other ph2
Would i have to fit a manual heater box?
I'd imagine you'll need to swap to a lower spec heater setup as the climate ones use motors to operate everything whereas others use cables, I plan on doing this myself buy haven't gotten around to it yet so can't say for sure unfortunately
they are totally different set ups, wiring, blower unit and heater matrix. It would be easiest to get the interior loom from a cup with the blower and matrix and swap it all over.
For no benefit whatsoever.
yeah exactly. Other than maybe a couple of KG. You do need to run the roof loom for climate though! must be 100 grams!
It does actually work without the roof loom however unless the controller is on min the mixer flap is all the way to oven mode as the climate registers -64 deg as the internal temp.
