CLiP isn't great for datalogging. RSTuner is better
Can one one u guys email me a ecu read ? Lost my other ones email is mi16205@hotmail.com
Thanks for the info. So does rstuner log things like knocking, injector duty cycle?
Fuel Part throttle : 1735 in 32kb file and 9735 in full read 9X20
Fuel full throttle : 814 in 32kb file and 8814 in full read 9X20 (cold?)
Fuel full throttle : 8c8 in 32kb file and 88c8 in full read 9X20 (Normal temp?)
Ignition : 392 in 32kb file and 8392 in full read 9X20 (cold 98 ron?)
Ignition : 446 in 32kb file and 8446 in full read 9X20 (normal temp 98 ron?)
Ignition : 4FA in 32kb file and 84fa in full read 9X20 (cold 95 ron?)
Ignition : 5AE in 32kb file and 85AE in full read 9X20 (normal temp 95 ron?)
Revlimits : 266E in 32kb file and A66E in full read 5X1 16bit LoHi
(cold/hot,Launch in launch-file,normal-temp,temp limit?, shiftlight on X rev before rev limit)
There is a few maps that i am unsure about:
I guess that 667 (8667 in full read) is lambda map 9X20
and those i have no clue
28C0 (A8C0 in full) is a map 13X17 16 bit LoHi
And 24AE is (a4ae in full) another 9X20 16bit map.
That from a full read ? Think I have a full read 172 somewhere.
Fuel maps are 9x20 and there's 4 of them.
Those maps are optimal spark Danny.
Ok found the 16x16 spark maps. Are we saying these are spark limiter map? Or the actual spark maps? If the actual ones then what are the 9x20 ones earlier in the file? Looking at a group n file the earlier maps are altered I think from memory. Not found the 16x16 maps in that file yet.
Great work buddy u have put so amount of time in to thisI've put a document together of what I've found so far. Hope it help users and hope users can add to it.
http://www.hidden-power.co.uk/wp-content/uploads/2012/08/Siemens-Sirius-32-34-Guide.pdf
ok think I've found the load axis some googling has come up with the factor and offset. Will up date the doc later in the week.
i have full winols!galletto lead
http://www.ebay.co.uk/itm/Galletto-...iagnostic_Tools_Equipment&hash=item2336126a87
drivers and read/write software
http://drivers.amazplus.com/download/CC45_Driver.rar
Tunerpro editing software
http://tunerpro.net/downloadApp.htm
There's no "normal" I've read from 2 cups in the last week or so, and they're both different in small ways.
checksums..........harder without WinOLS and the paid for modules you need, don't quite have that solution yet
i have both clones and neither talk to the Clio, alientech scrambles the checksums so is pointless, not tried a powergate but again these will be expensive, we want something anyone can afford otherwise it's pointlessGalletto and mpps clones. Or genuine alientech powergate s.
I've read my standard 182 ecu. Also have standard 172 and 1.4 16v files.
Anyway.....think we are all getting ahead of ourselves and messy along the way, firstly we really need to find something that reads the whole ecu, something that can also write, is cheap to buy etc otherwise theres really no point as, as someones already mentioned you might as well go stand alone as they are already leaps ahead
So we need
1 A Cable
2 Software that will allow to read(minimum)and write(hopefully)
3 A full read from a few cars so we have a 'norm'
4 Work the tables
5 Software to edit (loads)
So we need
1 A Cable
4 Work the tables
Who can map the GEN90? Ideally in the North West
