Do I need a new driveshaft?
  Mk1 Renault Clio RT 1.4
When taking my R/H hub off the end of the driveshaft has slightly been dented (picture below).
The hub nut doesn't slide over the end properly anymore - Would it be possible to just file this down?
Also what do you suggest for replacing the ABS sensors on both hubs? Renault want £160 per sensor! :eek:
Yep we, err, persuaded it out with a hammer - it was fairly well stuck in there! We'll try and file it some more and worst comes to the worst we'll replace it I guess.
Figured a new shaft would be more than £100 from Renault as they seem a complete rip off.
Cheers.
  172 ph1 ASBO SLAYER
will the nut start?
i'd try and file it then run a rethreader down the threads and see if its ok
  BMW M135i
Yeh i'd go with that ^. Its not as if the actual driveshaft is damaged, will be fine it you can get the nut started.
No the nut won't start, you're right I reckon it would be okay once we get it on the threads. Will file it more and look for a rethreading tool as you suggest.
Thanks a lot
