Do these look like PCD 100?
Car  Clio 1.2
Hi all, i am contemplating some OZ supertouismo's however, I asked the seller what the PCD was and to check on the wheel and he said that there was something like "B or D 100" on the wheel.
It also says in the listing that they were from a honda.
Heres a pic....
I knwo that the picture isnt too good, however I dont think that looks like the PCD is 100?
Any help would be appriciated.
Thanks.
^^ agreed, the only thing to watch is that some of the honda wheels have a smalller centre bore than renault.
but with these it will mean at worst that you have to buy some new spiggot rings.
^^ my bad.
OP, there is an alloy wheel guide stickied at the top of this sub forum :)
also make sure they are universal hub fitment or certainly the same size or bigger than 60.1 centre bore otherwise you'll have to have them bored out which isn't cheap.
I'd got some superturismos with eagle f1s on them in clio fitment going spare ;). They're gloss black though.
Ok well from what I found, some hondas have a bore of 56.1. Does this mean that I can use these "spigot rings" or am I basically f****d?
if they are 56.1 on the alloy you'd have to get them bored out, if they are universal fit hubs then you could use spigot rings if they are bigger than 60.1 to bring the bore down to 60.1 if that makes sense.
they should have the removable rings in the back, just get the seller to check and if so you are fine.
