O Or172 Car 172 ph2 Oct 26, 2016 #1 Hey Got 172 Ph1 : Bilstein B14 coilovers Front wishbones outer & inner tie rods Top strut mounts The question is : Does it fit 172 ph2 ? Thank you.
RichieJA SCAMMER !!!! Car clio 172 Oct 26, 2016 #2 I'm sure they only fit 172 ph2 non cup or the other way round. Someone will confirm
R Radugns ClioSport Club Member Car Clio 172 ph2 Oct 26, 2016 #4 172 cup has the same 54mm spacing as 182 non cup or as 172 non cup.
O Or172 Car 172 ph2 Oct 26, 2016 #5 You didn't got my question mate. It's between the 172 ph1 and ph2 - Both are non cups.
R Radugns ClioSport Club Member Car Clio 172 ph2 Oct 26, 2016 #6 From Pure Motorsport website it does fit you ph2 172.
O Or172 Car 172 ph2 Oct 26, 2016 #7 Ok,Thank you. Does someone know about the other parts? Front wishbones outer & inner tie rods Top strut mounts
Djw John Scotland - South ClioSport Area Rep Car Not a clio :( Oct 26, 2016 #8 Is it an early ph2 or late ph2? The later ones have different wishbones with more caster and longer tie rods. The early ones are the same. And all are interchangeable anyway.
Djw John Scotland - South ClioSport Area Rep Car Not a clio :( Oct 26, 2016 #10 That's right on the crossover for the extra caster wishbones!
