Does Any One Know How To...............
Car  Rsport182Cup'd
fit oil pressure guagues to the 182 clio, electric or mechanical, electric preffered.
i want to keep a closer eye on the oil temp and pressure whilst on le trac.
thanks
yeah its not hard, you can either fit a sandwich plate between the block and filter and tap off there, or tap off from the oil pressure swith on the front of the block etc etc
where do i get a sandwich other than greggs fred?
and just out of interest would vacuum go on the inlet plenum near the air filter
Hijacking your thread a smidge.. Is it worth fitting an oil temp gauge just so you know when you can drive a bit harder? Water temp is hardly a good way of telling when the engine is warmed up :p
the oil pressure was a practicality issue, the vac was interesting if i had a spare pod for it to fit in to.
whos guages do you use fred, i want some that match the car, the nearest i can find are raid ones, they are amber dialed like the car,
i want pod guages and fittments and instructions, paypal waiting.
I was going to suggest those as well....you can have oil temp and pressure in one gauge.
Better fitment with senders as well....I'd be a little uneasy at the thought of hot oil flowing around tubes inside the cabin which is what you'll get with some more simple gauges.
