door card removal
green
Car  Hi comp phase 1
Hi as above on a 172 mk 1. I have taken out the screws at the bottom of the door card but its not coming away from the door.
some help please
Have you removed the screw in the interior door handle and inside the door pull?
(Disclaimer - It's been a few years since I've touched a Mk2)
I wrote a quick to-do list in this thread:
http://www.cliosport.net/forum/showthread.php?t=375528
I'm sure it's not perfect, but it should get you on your way. I forgot to mention in that post that there a two (I think) pop clips behind the door card, at the end furthest from the hinges, but they should pop out if you do the rest anyway. Also, you won't be able to unclip the window switches until the door card is mostly off.
cheers Ian and symon. the thead you did was very useful
thanks
