doors on the wonk
Nafoff
opened it tonight and the wind took it, it went right back pretty quickly
i shut the door and went into the gf's, when i came home i got in and closed the door, it didn't close properly, and then again when i got out when i got home, it seems to be hanging low..
any ideas?
on a valver
Pep
  M2,XJS,S1000RR
wind did this to me door, onto a f**king wall, massive flat spot, chipped the paint etc, so pissed off.
pretty sure its gonna cost me a lot to get fixed, gutted
  182 Cup
Same thing happened to my old 1.2, wind took it, loud crack noise and the door always wobbled a bit when it was opened from then on.
Do the gently pulling up thing as already posted.
Nafoff
i have had a look, i was thinking it was the door pins if they are the 2 bolts above and below the hinge, if so it does look like that is where the play is, is it a case of new door pins or can i adjust these to suit?
also what tool do i need for the bolts as i can't really see them
  Trophy #473
just slowly but agressivly pull the door up when fully open, the hinges are very strong as they are welded on so will need a good pull to bend back into alignment, wont need much tho, maybe also readjust the catch on the b pillar too.
Nafoff
^^^he's the man
shame i couldn't adjust the catch on the b pillar, the catch strap bolt had stripped the thread in the pillar straight out, was a task sorting that after a tool mechanic re threaded it with a 9mm thread..which if you didn't know are highly rare
sorted now though....cheers dan
