Drive shaft popped out
Car  181
I was changing the dci ball joint today. Driveshaft popped out the rubber seal on the ns and oil pissed everywhere
Is it ok to cut the old clio off. Jubilee it back on and fill it up?
yeh cut it off and jubilee clip it but it will still leak, ideally you need it clipping with the correct clip.
nice oil patch on the drive?:quiet:
it just pushes back in/on, no need to cut anything (you will have to remove the shaft from the car to do it)
