Driver side seat wont move
  Clio Sport 200
Basically the drive side seat lever which allows it to tilt forward will lift up but the seat won't budge, meaning if I have more than 1 passenger they all need to get in the passenger side door.
Does anyone know anywhere in the North East that would take a look/ repair this, or does anyone know what the problem may be?
Ads29
  Clio 172 Merc ML55
The tilt mechanism is cable operated, I imagine that this cable has broken in the seat back, when you lift the handle to tilt the seat it operates a locking bar across the base of the seat, slide the seat as far forward as you can and you should be able to see the mechanism and lift it manually.
