Drivers side driveshaft help needed
  clio 172
Were in the middle, all of the hub is removed, undo and too bolts out of centre bracket but still cant remove it !
Should it just pull out or is there summit else retaining it ?
Daniel
  Whichever has fuel
We're in the middle of doing it, all of the hub is removed, we have undone the bolts out of centre bracket but still cant remove it !
Should it just pull out? or is there something else retaining it?
Thanks in advance, Finch.
Edited.
  ph1 black 172
with the driveshaft nut undone and the hub is away from the lower wishbone, the drivers side will just pull off as its just pushed on to the gearbox.
  clio 172
sorry, im outside trying to remove the driveshaft as we speak !
the bolts are removed from the centre support but the driveshaft doesnt want to pull out ?
is there any guides on here or can someone advise ?
  clio 172
yes they are all removed, as well as the centre bearing brackets bolts, should it just pull out now ? it doesnt seem to want to move !
  Lionel Richie
oh just read it again, the 2 13mm bolts on the centre bracket are off and the retaining plate if off correct?
  clio 172
funny f***er, it doesnt go dark in wales and ive had carrots !
shaft is now out !
how do you go about remover the inner cv rubber etc,is it pressed in ? can it be replaced ?
euro car parts do a kit but dont know if this is what i need!
  182
shaft is now out !
Haha! Does it reli not?
  "Navy" N17 TWO
Think they are £120 from Renault
Not sure if that's + or including VAT though
Finch - what's wrong with the shaft anyway, out of curiosity?
I replaced the inner gaitor on mine fine, I got the boot from sideways danny and fitted it to my 172 shaft. Its nowhere near the engine block if you use the same type of clips as that came off!
CLIO-Si
  1.6Si + 182
no 1 even told him to get a small pin/punch to finally get his shaft out when everything was (UN)boltd
