Driveshaft change... What else is needed?
Car  BG 182 FF
Looks like the o/s driveshaft is definitely dying so time to change it. Other than the driveshaft what else am I going to need...
New driveshaft
gearbox seal?..
hub nut
gearbox oil
Anything else?
Off side is the drivers side, it doesn't affect the box oil?? (Unless you're just changing it anyway?)
Brilliant, so it's actually an easy enough job then. Just a new hub nut and driveshaft. Worse bit will probably be getting the nut off.
